Uh correct me if i'am wrong but aren't they rated at just 300 horsepower and 320 lbs ?saeedakobiakov wrote:last night i lost to to new style mustang gt, sucks, but i had to try it to see what if? i knew i will loose.
we were at around 80mph. he was behind me, so did what i had to do, but at around 120 he pasted me.one thing i notice that it took a while for him to do so.and defiantly he got more juice at higher gear/speeds.
mustangs are at 3550 lbs with 315 hp and 325 lbs.they run mid 13s at 102,103mph.
life must go on. i had fun.that is all .Caug.
actually i think they can hit around 150+ and aren't limited to 130.maxnix wrote:Aren't they capped at 130 mph? Should have just stuck with it.
There is a limit of 155mph. But if the computer is reprogrammed, the limiter is non existent. i've had mine up too 152mph driving through New Mexico going to AZ. Still had a little pedal left. On the newer stangs (05+) it's hard to get to 150mph due to the aerodynamics.MagicM wrote:http://www.youtube.com/watch?v=fmS4DUNeDGI, guy gets it up to 149mph, apparently there is a limit at 155ish, so it could hit more if you took it off.
