With absol
redtop91 wrote:Sounds like a bad ECU.....
utely no troubleshooting you are telling people to buy a new ECU? WTFGKY Quit padding that post count. I know your only trying to help the person but telling them to spend $400 with out even troubleshooting anythign and later on throwing out false information in later posts is not something ther person wants or needs.
As above Cam Angle Sensor does control both fuel and spark. Unless you cracked open your valve cover or moved the CAS then i would leave it alone physically and check the wiring. Do a search of the archives
DRFT240sx06 the clips being missing on your injectors will not cause an issue with them as long as you unplug them and inspect for corrosion. If you see vertigreen then you need to get some QD Electrical Contact Cleaner and clean them up with the QD and a soft bristle brush (brass is the stiffest i would use) This cleaning method applies to all terminals.
IF your car in a fresh swap and has never started then there are a few things to read.
http://www.heavythrottle.com Go to the Install FAQhttp://
www.frsport.com/index.p...id=20
After you read them and get familiar with what your wiring should look like and what goes where. Come back and repost any questions you have. I am not pushing you away but from your other topic going it sounds like shes not wired up yet.
