s20det emissions removal
auto alchemist
Car: 1992 nissan 240sx se
yes i searched and i found a bunch of stuff for the ka, but i need to know what emissions stuff i can take off, and pics of those parts if you have them
this is for an s13 blacktop
marcus8789
Car: 95 NISSAN 240SX
Where do u live? (cali?)
CMG
Car: 1989 240sx Hatch w/ Redtop
You can take off all the emissions stuff. All you need to do is either re-route or block off hoses and stuff.
auto alchemist
marcus8789 wrote:Where do u live? (cali?)
ohio, where i live they got rid of emissions testing so i can take off anything i want, but ive never had an sr so i dont know which parts i can take off, i know i can take off all the emissions equipment but i need like locations of where these parts are, or pics would be great
CMG
If you want that much info you're gonna have to search. I took off all the emissions equpt on my sr, but it seemed pretty self explanatory to me.
auto alchemist
well i dont get the engine untill tomorrow so i havent had a chance to look at it up close yet, do you need a block off plate to remove the egr valve on these, because i did on my ka
Hijacker
Car: '92 240sx Convertible
'94 F-150
s13 SRs don't have EGRs. They have AIV valves which allow air to bypass the motor and go directly into the cat to help it light off at idle. That gets removed regardless of where you live because the AIV tube contacts the steering column. In any case you need something to plug up the hole in the turbo extension after you remove the AIV. In our parts thread sticky there's a Nissan part number for a plug. Or if you're handy with a welder you can fab up a plug out of the old pipe.
There's no intake hole to plug up as the AIV pulls unmetered air from the stock airbox.
As far as emissions go, that's it for SRs.
auto alchemist
Hijacker wrote:s13 SRs don't have EGRs. They have AIV valves which allow air to bypass the motor and go directly into the cat to help it light off at idle. That gets removed regardless of where you live because the AIV tube contacts the steering column. In any case you need something to plug up the hole in the turbo extension after you remove the AIV. In our parts thread sticky there's a Nissan part number for a plug. Or if you're handy with a welder you can fab up a plug out of the old pipe.
ok, thanks that helped alot lol
so that tube goes into the turbo elbow? because i have an afermarket elbow thats going on and the only hole in it is for the o2 sensor so i shouldnt have to worry about that
