Built2Slide »
https://forums.nicoclub.com/built2slide-u134699.html
Thu Jun 25, 2009 8:44 am
I did a s2 swap in my 240 and i see there were 2 tps, one was a switch and one a sensor. one goes to the main ecu but the other one went to the in cabin plug like you said. I powered the one which i believe was a blue with black or vise versa. My car starts but will not idle with the MAF connected but will rev. With the MAF disconnected it will idle but no rev.
Have you seen any of this yet, and what did you find out about those wires? One more thing, what did you do about the air valve on the bottom of the intake manifold wiring, it also goes to that same in cabin plug that had those TPS wires....right now mine is not hooked up.
Thanks for any help
