You dont need an ignitor at all. There is no repinning of the harness needed either. Im running a 16bit 1994 n/a z32 computer that I modified internally and I run a nistune board and it works great. S2 has built in ignitors in the coils so you can run them with no problems. I can modify the ecu for you if you want. Email me at
[email protected]. You can run a stock z32 twin turbo ecu no problem without nistune. I even ran a n/a 8bit for a while with a z1 stage 3 chip just fine. The n/a computers are cheaper and have the single stage fuel pump controller. You will need to run the z32 n62 maf though.
DustinZ
