rocketman240 »
https://forums.nicoclub.com/rocketman240-u70934.html
Wed Apr 01, 2009 4:20 pm
Take screw driver and pop off left and right cover.You get a Torx-50 tamper proof bit and take a screw off on each side.Pull off air bag and unplug wire. Put some place SAFE.Unplug the horn.Remove main nut. Set aside for new wheel.Use steering wheel puller. Put steering wheel and air bag back together.Brake off the plastic post on the the clock spring. So the S15 wheel will fit on.Turn spring to line up with the wireing harness.Put nut on and tighten.Plug in horn.Put air bag on and bolt in.Plug in air bag. Replace covers. I just swapped mine last weekend. I have a '95 built in '94. So I had a couple problems afterwards. Some clicking/poppping noise and the turn signal and washer arms flexed when turning the wheel. I solved this by taking wheel back off and taking the clock spring off to see how much I needed to shave off the wheel. So I lined up the spring harness with the wheel at the 6 o'clock postion, and grinded out about a 1/4" to 3/8" with a dremel. Now the plug harness doesn't throw off the alignment of the wheel when installing.
Modified by rocketman240 at 7:57 PM 5/14/2009
