s15 turbo
dray3OOO
Car: 90 rb20 hatch HKS everythang
77 corolla stroke 2tg 40mm mikunis
im plannin on doin a t28 setup on the ka will i have any fitment problems using the s15's turbo, because its right in my goal range. im using a custom log mani from jgs.
S14toRPS13
I've just recently started researching about KA-T's but I think the JGS manifold come with a T3 flange?
480sx
Car: 1996 Pearl White 240sx
Yes, you will have a problem with a s15 turbo because the flanges on the exhaust manifold you want is a t3 flange, while a t28 is a t2 flange.
A t3 sized turbo is a much more efficient for the big 2.4 li KA.
dray3OOO
o ok thanks guys
WI_S14_Goldie
Car: 1995 Nissan 240sx SE, 91 240 fastback LE, 1997 kouki S14, DD = 93 Nissan Maxima
Yes a T3 will be "better" but its up to you! With a T28 you can achieve numbers ranging from 230-270 depending on ur set-up. If u've got one in hand use it! U'll Spool just like a T25 but it'll hold up more boost.
dray3OOO
yea im on stock block also with a 130kk (well takin care of tho) so t3 shouldn't be a problem right i have no rod knock or anything and my compression still good. i have searched on the forum alot guys are well over the 350hp range with stock block and many that blew theres, but alot guys blew thiers was because of there tune. so i guess ill take my chances **** it.
Zippy69
Car: 1993 240sx coupe
Everything I have found points to ,good tune= lots of power and fun.Bad tune = lots of money and heartache. If you have the knowledge, then tune yourself with a safc or emanage etc. But I don't have the knowledge yet so I chose to have a tuned ecu. I got mine from e-mance, but everything I read about his ecu's were good. every review said he had a great tune that was right where it needed to be. I'm not pushing his product, just stating what I found.I should have all my turbo set up installed and running this weekend and I plan on posting a review of my e-mance tune. So stay "TUNED" tee hee.Sorry, couldn't help it
matthunter8819
Car: 92 nissan 240sx coupe
I am selling a garrett t28 gt28r turbo for $850. It has never been used and i can throw in the turbo inlet and outlet flanges as well. It is a dual ballbearning turbo that has really quick spool time and works well with the ka. up to about 315 rwhp.
