s15 turbo question
MakiGTP
Car: 93 240sx se
which turbo is on the s15 sr auto motor. is it a GT28 or what
SpeedRacer1
Car: 1990 240SX, G35
S15 auto's got S14 T28 turbos.
mallbor240SR
Car: 240sx 1990
can you tell the difference between the gt28r and a s14 t28 turbo just by looking at some pictures?
SpeedRacer1
I can tell by looking at the part number plate.
mallbor240SR
Car: 240sx 1990
what about the one with the part number 14411 69f00i know its a nissan t28 turbo, but is it ball bearing??is it worth 600 dollars ? brand new
ILikeMy240sx
Car: SR Power
S15 Spec-S came with regular T28 found in S14s. S15 Spec-R came with T28 with dual ball bearing.. You can tell this by looking at the exhaust housing on the turbo and it should have a divider between the waste gate and where the turbine wheel is.
mallbor240SR
Car: 240sx 1990
so the s15 spec s turbo isnt ball bearing?
ILikeMy240sx
Car: SR Power
Somebody correct me if Im wrong but T28 found in Spec S and S14 is ball bearing but NOT dual ball bearing.
SpeedRacer1
14411 69F00 is the turbo from the S14 SR20DET and S15 SR20DET Auto.
The Spec S got an SR20DE so the turbo is "NO BEARING!"
Dual ball bearing? ball bearing? The centersection is ball bearing or journal bearing. There is no extra ball bearings in S15 turbos and there is no half and half turbos.
karmakaze
Car: 98 240sx SE
the automatic s15s got the same bb turbo as the s14s. the 5-speed s15 has the gt28r which can be easily identified by the dividing wall next to the wastegate.
mallbor240SR
Car: 240sx 1990
[QUOTE=SpeedRacer1]14411 69F00 is the turbo from the S14 SR20DET and S15 SR20DET Auto.
so if the spec S got an sr20de, then i didnt came with a turbo,
SpeedRacer1
Didnt get the joke eh? Yes the Spec S is a non turbo model.
mallbor240SR
Car: 240sx 1990
hehehei got it nowbut s14 spec s from australia are DET
SpeedRacer1
Well S13's in Europe were called 200SX's and came with CA18DET's, explain that. Nissan lables are always messed up.
