i have those parts already. i mean as far as mounting the turbo to the exhaust manifold and everything lining up? some for not specifingPapaBurgundy wrote:Youre going to at least need injectors, some form of tuning and preferably a better than stock fuel pump.
i got steel braided lines and i think the water lines are capped off. i got a sr down pipe and elbow. thanks for the info.float_6969 wrote:The stock oil and coolant lines will work, but will need some careful bending. The oil drain line flange holes will need enlarged. If you're using a CA18 O2 pipe, it might be different.
thanks for you help.float_6969 wrote:Do NOT cap off the coolant lines. Ball Bearing turbo's require coolant to function properly. Because of their reduced oil needs, they need engine coolant to keep the center sections's temperature down.
DO NOT CAP OFF YOUR COOLANT LINES TO YOUR BALL BEARING TURBO!
