s15 turbo on a red top! what needs to be done?
jdmben
im getting ready to put a s15 turbo on my s13 redtop and i heard that some modification needs to be done to the water/oil hardlines and the oil return tube on the turbo. anybody know anything about his please let me know if you know someone who has done this thanks ben
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
one bolt on the O2 sensor housing isn't going to line up, you're going to have to clock the compressor housing a little, and you will have to slot out the flange on your oil return fitting to work with the new turbo. Also the oil return line has to be bent slightly or just cut it off and clamp some braided stainless over both ends.
the water lines and oil feed should go right in, just takes some re-bending of the lines
later,
Paul
