S15 Turbo Oil Line
ca18detdrift
Car: 89 240sx
My s15 turbo has a small leak (over night leak of a few oil drops), i was wondering if anyone knows where i can get the stock oil return line for the s15 bb turbo?
ca18detdrift
Car: 89 240sx
I just went to the junk yard to get a fan shroud and I noticed the ca20e radiator looks like it might work for an s13, also it is about twice as thick. Can anyone confirm if you can use a ca20e stock radiator on your ca18det?
Also would the powersteering pump off a ca20e also work? it all seems like it might work.
tyrannix
Car: go big or go home
bring a tape measure next time you go to the junk yard, if the in and out are both on the right-hand side and the top-bottom, left-right dimensions match (or are close) then yes, it will work, you may have to get creative if the screws dont match, those bigass zipties are great for things like that (thats how i mounted my dual elec fan... 4 huge zipties at the screw mounts)
