I haven't seen any substantial data to back up the theory that the S15 SR transmission is weaker than the other SRs.Scuffed_ChukiCoupe wrote:Is there anything tht goes commonly wrong with these transmission. Would you perfer it over a s14/s13 sr transmission ? Any info would be appreciated.
ive heard the same thing, think about it, same gearbox and another gear. you do the math. go for a s13/s14 transmission.david200095367 wrote:I heard its a little weaker because every gear has been slimmed down to fit into a 5spd gear box. Also i believe the s14 sr transmission is the strongest.
There's some kits you can buy to get the signal, you looking for a 6 speed cody........hey what was the lifespan on your block before you went with CP's, I am almost done with the head build and wondering if I should start on the bottom end or run is and see what up, also my engine had about 50k miles on it before starting the build, never was modded or anything before thatcodyace wrote:how does one get around the speed sensor issue?
you can swap out the whole rear end with an s15. i think if you have an s14 se w/ abs and vlsd, you have to swap out the dif w/ something like a kaaz. i might be wrong, i know heavythrottle.com has the swap w/ the difs. and im pretty sure that you have to get a 1 piece drive shaft. someone correct me if im wrong.codyace wrote:how does one get around the speed sensor issue?
If I had the money and had a power goal of 250-300rwhp I would probably go with the 6 speed.
Thats the thing I was talking about, there's a few others out there as well.CoupedUp wrote:To convert the S15 Rear Differential VSS signal to a compatible S13 or S14 Tach signal, you will need the Dakota Digital SGI-5. It will convert the S15 VSS Pulses per Mile to the correct one for inputting into your existing tach.
http://www.dakotadigital.com/i...6.htm
No problem, calling me out by name. Dayum. LOL.Hijacker wrote:Ahah! Thanks, Sean, I couldn't remember the name of that little guy
