s15 transmission
starler99
Car: Projet Cars Only
would an s15 6 speed transmission fit in a 240sx fastback with an s13 blacktop sr20det?
captain nismo
wow. thats an intresting combo. I dont know if it will work easily, but with lots of $$$ anything can be done... :)
red240ne
Car: mmm...donuts
yes, keep the bellhousing but throw in the 6 spd gearbox.
R240NA
No. The bellhousing is different, it won't swap over, and the VSS signal is summed from the ABS sensor located in the differential on the S15, the driveshaft is also different.
mmdb
I've heard of people swapping over the 6 speed into the s14 sr20det but not the s13. I would assume u can knowing that you would need the flywheel, clutch, rear diff for the speedo... correct me if i'm wrong. I also heard from several others that an auto driveshaft can be used from a s13 because it's longer and the spline count is the same.
