gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Fri Jan 12, 2007 5:19 am
this question is so vague... i assume you mean will an s15 transmission bolt to your RB which is eventually going into an s14? nothing has a problem fitting in an s14. hell you can put the transmission in your trunk if you wanted.
but i assume you mean "can i use an RB front bellhousing, place it onto the S15 transmission, then bolt that onto my RB motor". If thats your question then you should phrase it that way. My guess is I highly doubt it will be a direct bolt up, but hey give it a shot who knows
