extheflow »
https://forums.nicoclub.com/extheflow-u3097.html
Wed Mar 12, 2003 2:10 pm
Quote »The motor itself will drop right in. The transmission mount will require some modification (drilling) and such. The wiring is unknown because not many peeps do this to begin with, but I think it's not too different.[/quote] the transmission mount does not need to be modified if you use the S15 mount.i just dropped mine in over the weekend.S15 into 96SE. every bolt lined up perfectly. the motor bolts right up like it was meant to be there.one of my friends made a wiring diagram for me, but he spent alot of time on it so i don't know if it's public domain yet or not. but if he gives it up i'll include it on the website i'm making documenting the whole procedure.oh yeah...the S15 diff requires the use of the s15 driveshaft,the output shafts are the same as S14 and the carrier bolts directly to the subframe.i haven't had to bust out a grinder or unibit yet:ylsuper ben
