ca18det240hatch »
https://forums.nicoclub.com/ca18det240hatch-u57383.html
Wed Aug 01, 2007 2:13 am
to make that turbo fit you can clock it. what you do is undo all the bolts around the intake side of the turbo, then you spin it wherever you need, and tighten them back up. The oil drain differs from the ca18 turbo, you will need to use the s15 or s13 one and a longer chunk of hose.
as for running the butterflys open all the time, the way we set them up here, without running the solenoid and all that other junk, theyre open right away anyways as soon as you touch the throttle, so i cant see any real gains from taking it off and removing them as opposed to just leaving them hooked up to constant vacuum.
