95lstegman »
https://forums.nicoclub.com/95lstegman-u33967.html
Tue Oct 03, 2006 9:21 am
get a standard GT28R. the lines will fit perfectly that way, although you'll have to clock it to fit. but it's new, so no big deal there. i think you can even order the GT28R with a properly-flanged compressor housing, although i don't know if this option comes only as S15-spec meaning different fittings on the center section. in any case a turbo capable of 300whp day in, day out should probably not be restricted to breathing through a 2" hole. you replace the MAFS and remove a huge bottleneck (aside from the obvious change in sensor voltage readings), why stop it up at the turbo?
