BaliLover »
https://forums.nicoclub.com/balilover-u6785.html
Tue Aug 03, 2004 8:43 pm
From what I've seen, the 2 turbos (s15 T28 and GT28RS) are fairly similar. Don't use a drill bit to slot the oil flange, instead use a die grinder or a dremel with a stone, it didn't take me long to do mine. I had NO problems bending the lines to fit my GT28RS, just be careful not to kink them. I believe I did this off the car and just kinda looked at my bends, then in the engine bay to see how it needed to go.
As for the outlet, I found some truck radiator hose that was the right diameter with a 90 degree bend, and used that for a coupler. I've been pushing 14lbs for months now with no problems at all. I connected this to my enjuku hotpipe so I'm guessing it will also work with the stock pipe.
The Intake is a PITA, the stock one for sure won't work with the GT28RS, not only is it too small in diameter, the GT28RS doesn't have the elbow that the stock T28 has so the bends are wrong anyway. What I did, and its worked since I fixed a slight problem 2 days turbo install, was use a cooling duct from the ricer section at autozone. Its black plastic flexie tube, thats 3" diameter and comes with 2 pretty nice clamps. ITs plenty long and it bends really well, so its not too bad to snake around the engine bay. If you're using the stock MAFS, you'll need to make a bushing out of some pieces of rubber hose so that the duct will fit onto it and not over it. The little problem I ran into is that being plastic, it is prone to melting under extreme heat, and it runs close to the manifold. It got too hot and melted some holes. I cut of the melted section, stretched it out a bit more, and reconnected. I then took some pieces of radiator hose, split them down the middle, and wrapped the section of pipe just under the manifold with it. I then used a couple of zipties to hold it in place and I haven't had a problem since.
The pipe I refer to was 19.99 at Autozone, in the ricer section, and the packaging suggests that it is to be used as a cold air duct to flow air from under your bumper to your airfilter. THis is not a CAI though, just a duct.
