There is no length difference between the s13, s14, and s15 transmission. They crammed the 6th speed in there.
And rocker arms will bolt up the same since they fit all s13, s14, and s15 engines. The only thing you will have to do is grind a slot in the s15 valve cover for the RAS to clear. S14 valve cover is the same.
The best thing for the speedometer is to get a dakota digital speedometer converter. Not sure the proper name but its made by dakota digital.
As far as intercooler, you should be able to use everything you have on your s13 front mount except for the cold pipe. I have a s14/s15 cold pipe for sale if you need it. Its a greddy cold pipe but should work with any intercooler brand. If you don't already have a front mount, then you should buy a s14/s15 one. May need to modify some mounting points but thats easy.
And as far as the angle for the turbo. You can buy clocking adaptors. I actually have some for sale. I can get you a pic. Just send me an email at
[email protected] if interested in either the coldpipe or clocking adaptors.
