S15 SR Vacuum lines Help!
koukiguy13
Car: 1995 S14 with S15 Motor- 2001 Lifted Chevy CrewCab 2500HD
Can anyone here tell me how to run the vacuum lines without using the charcoal canister? I searched but dont understand the diagrams Ive seen.Thanks.
SpeedRacer1
Car: 1990 240SX, G35
Its pretty simple, trace the vac lines back to their sources and cap them off. The line underneath the canister that goes to the hardline (then to the gas tank) gets capped to.
Keep one line going from the intake manifold vac lines to the BOV/recirc valve. The wastegate gets its signal from the hot/cold pipe.
koukiguy13
The problem is I cant track them because there are no lines hooked up. I think there are 3 fittings underneath the Intake manifold and my bov is on the coldpipe.
SpeedRacer1
Cap two of the fittings on the intake manifold and the other one goes to the BOV.
