Is there any other diff that i can get to make my vvt work besides the s15 diff. So i've been told, there is a sensor on the pumpkin of the s15 diff that is required for the vvt to work.. Any knowledge would help.
There is no VSS on an S15, the ABS sensor in the rear differential sends a voltage signal to the ABS system and it gets converted from there into a speed signal for the cluster.
