s15 SR into s14 6speed question
goldeneye9mm
Car: 95 S14 240sx
i really want the s15 sr20det w/ the 6 speed so i'm wondering if the trans case is the same size. ie driveshaft length. and anything else or other info on this swap would be helpfull. thanks
CoupedUp
Car: 1993 Coupe
Driveshaft length will be different, youll need the S15 Rear Differential(maybe halfshafts too).
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
Why would you need the S15 rear diff? Because of the gearing?
CoupedUp
Car: 1993 Coupe
The speed sensor on the S15 is in the rear differential.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The speed sensor for the s15 motorset is located in the diff casing (as opposed to the transmission for s13-s14). A Bonus is that the s15 helical LSD is totally saucy if your into grip driving. Definitely not bolt-in though...
BTW s15 diff output stubs bolt up to s13 and s14 axle shafts.
ddgsxr504
Ahhh now da student has become tha techa! Thanks guys didn't know that.
Modified by ddgsxr504 at 5:12 PM 8/14/2007
goldeneye9mm
Car: 95 S14 240sx
ok so i'm guessing it would just be easier to put the s14 sr20det in? i just really wanted to have a sixth gear. i have an 06 spec v too and i like 6 gears. oh well. other than wireing the sr20 pretty much drops onto the old mounts and everything right. i knoe cooling, intercooler routing and exhaust has to be swapped but thats about it right?
CoupedUp
Car: 1993 Coupe
I wouldnt reccomend jumping into the S14 SR into the S13 Chassis unless you are pretty knowledgable OR are gonna send the harness off to be done professionally.
CoupedUp
Car: 1993 Coupe
I think you have an S14 anyhow. So nevermind. ; ).
ddgsxr504
S14 SR into an S14 is direct drop in. The heater core hoses need to be re routed to in the other direction, the upper radiator hose has to go across the front to the other side (unless you have the SR radiator). The wiring harness is pretty simple, if you search it can be done yourself. There are only like 3 wires that need to be spliced. If you want to retain A/C you can reuse the KA pump (3 out of 4 holes to the block line up) which will eleviate the problem of draining the freon and hooking up all the SR A/C stuff to your car. All clutch and drive shaft stuff line up.
goldeneye9mm
Car: 95 S14 240sx
awsome. thanks for the great info. i know i coulda searched but i already had a thread started so i figured i'd ask. thats sweet that it just drops in there. i'll start looking for a motor and trans soon.... very soon
nyjays
Car: 1995 nissan 240sx
well u can get the s15 engine and transmission and diff, and also get ready to spend about 4,000 to 8,000 to get her running right, i think so far i spend about 6.5 maybe more, and for the driveshaft well i made my. i use my old one and i just cut it, and fix it and got it balance. anyways the big problem is if you are looking for horse power "over 320" since nissan didn't make the s15 transmission that strong but if u are will to pay get the transmission rebuild with stronger gears (that was a big thing in japan when i was there since i had friends that where smoking r32 and r33 and others cars like nothing)
<br/>Shot with DSC-P200 at 2007-08-16
doridori23
Car: 1996 SR20deT 240sx (mine) , 1998 KA24de (wife's)
nyjays wrote:well u can get the s15 engine and transmission and diff, and also get ready to spend about 4,000 to 8,000 to get her running right, i think so far i spend about 6.5 maybe more, and for the driveshaft well i made my. i use my old one and i just cut it, and fix it and got it balance. anyways the big problem is if you are looking for horse power "over 320" since nissan didn't make the s15 transmission that strong but if u are will to pay get the transmission rebuild with stronger gears (that was a big thing in japan when i was there since i had friends that where smoking r32 and r33 and others cars like nothing)
The 6-Speed is a weak trans as stated above and even if given a S15 RHD car I would sell it and just buy an S13/14 depending on the chassis putting it into.
nyjays
if u got any ? just send me and email at jay2002mp@yahoo but for right now i like my advise get s14 engine and with transmission for now since if u looking for power u can spend the extra money later on a better turbo and other upgrades and then get a 6-speed transmission and get her rebuild if want to u dont need the s15 differential since "dakata digital got a box that take your rpms sinals to your speedometer but it is to much pain in the *** since it got to be adjusted to" p.s do your research like that u dont waste your money
nyjays
it is week but u can rebuild the transmission many people do it japan is just that is more $$$$$$$$$$
goldeneye9mm
Car: 95 S14 240sx
yeah thanks for the input. what do you guys think of a complete instalation turn key swap for 7500? i found a shop yesterday down the street. thats everything including motor, trans, installation, frontmount intercooler, exhaust downpipe, electric fans... evertyhing. lemme know
doridori23
For an S15 that is done right the first time it sounds ok to me. I personally would like to see it around 6000 but the S15 is a quirky little beast and requires more work so as long as it runs right afterwards I think the price is fair.
goldeneye9mm
Car: 95 S14 240sx
no thats for an s14 sr20det. but lots of extra. i discussed the bare minimum swap was like 5800. but i like go fast much. it should be quite nice once done. i am going in on the 27th to start. ani i bought the cleanest freaking motor i've ever seen. it looked garage kept for real. i should have it back by the first at the latest. i'll post pics and all as soon as it's done
