S15 SILVIA 480CC
xero1
Car: 08 Altima Coupe
whats the max rwhp i can get out of 480cc injectors? i have a s15 trubo.
S13FASTBACKSR
Car: '92 Fastback SR powered
From what I've heard they are good for about 300-320 hp at the flywheel someone correct me if im wrong
SR20Essex
Car: 1989 Nissan 240SX, 2007 Infiniti G35 Coupe
My setup is getting about 309 to the crank out of 370cc injectors (S14 SR & S15 turbo), my dyno shows 262hp at the wheels, so if you calculate an 18% parasitic loss (1.18 x 262 = 309.16hp). I’m running 13lbs of boost, but I have all the goodies... Strait through 3in exhaust/dump pipe/down pipe, intake, FMIC, Aluminum drive shaft, aluminum underdrive pulleys, Splitfire coil packs, hyper grounding system, the list goes on that all adds up to HP created beyond just adding more boost.
SuperScooby
i heard that they actually only flow at 444cc? is that true?
