rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Sat Jan 22, 2005 10:33 pm
See, that is the weird part. On NissanPerfMag* they didn't mention any modification needed. They even made a point to mention how easy b/c the holes all lined up. I mean, it was only about 15sec with the RoboGrips to get the thing lined up (the rest came when tightening the the bolt with a 1/2 drive w/ a 9" length). I dunno. Easy enough to write off.
The only hard part was lining up the back right hole (when looking into the car, the one on the lower right of the seat) up with the bracket*. See, the opposing fastener on the top right is actually a stud, welded through the floorpan, that you prop the hole on the bracket onto, then fasten in place with a nut. This limits motion a lot, so you have to give pressure to line up the back hole (that is closest to you) as it is about 1/4" off.
*http://www.nissanperformancema...240sx/**
