hai1206vn wrote:I'm trying to swap in the S15 HLSD, but like many people, can't find the proper Nismo ring gear bolts. I also read about fabricating sleeves or using starter bushings to wrap around the S13 bolt neck.
So one more option is to throw in the S15 ring ang pinion (higher ratio no problem) and use S15 bolts. Has anyone done this? Will they fit right in?
i've had the HLSD in my S13 open diff pumpkin with ALL the old hardware with ZERO problems.
just use your old bolts and give me the ring and pinion gear because i want them
