when i was doing mt swap i called them they were not of much help, actuallt yuri from wiring sepcialties was more help.
i used the s15 transmission , why else would i go for the s15 swap if not for the six speed transmission
if you use the s14 transmission then you should be able to use the s14 speed sensor. the whole thing with the speed sesor is that if the s15 ecu does not recieve a speed signal it acts wierd something to do with variable valve timing. if you use the s14 transmission then technically you should not have to make a custom drive shaft, the reason one has to make a custom drive shaft when using the s15 transmission is the difference in the yoke and the s15 drive shaft being shorter due to s15 having a shorter chasis and the six speed transmission is a bit shorter than the 5 speed one thus the whole modification of the transmission mount if you use the s15 transmission. very easy to do. and as far as the basic 240 goes the chasises are the same so it wont matter if you are using a basic 240 or a SE . there is not much info on the net about s15 swaps but the other info you can just search for it
good luck with whatever choice you make.
