S15 Nq Ecu Not Starting an S15 sr car wired up for a Qt ecu, why?
Madngineer
Car: s14's 95 w/rb25det 97 w/sr20det
hi, I just bought an ecu for an s15 sr20det, i tested it on my friends car. His car has a QT ecu which works fine. I hooked up my NQ ecu to the same car and it would not start. The car cranks and the fuel pump turns on. I was told this ecu was from a turbo car, the numbers are NQ 23710 91F08. What can i do to verify the identity of this ecu and make it work.
thanks steve
QT Ecu
NQ Ecu
Modified by Madngineer at 6:02 AM 6/8/2009
slidestyle69
Car: 92 s13
what is qt and nq?
Madngineer
slidestyle69 wrote:what is qt and nq?
lol..............thats what my question is.
slidestyle69
Car: 92 s13
lol are these s15 ecu's or ecu's from another motor?
Madngineer
slidestyle69 wrote:lol are these s15 ecu's or ecu's from another motor?
they are both s15 ecu's. The Qt runs an s15 turbo engine. The Nq turns the fuel pump on and turns over the engine, but doesn't run it.
jr_ss
Car: 95' S14
The NQ is most likely an SR20DE ECU, meaning it won't run your car because there are different I/O's from the SR20DET.
slidestyle69
Car: 92 s13
thats true, good point. it seems just like when u plug a ka computer up to a sr the fp primes and turns the motor over but wont fire it off.
I was reading back on a couple things you said, the qt ecu wont start the car or have u jus tried the nq.
jr_ss
Car: 95' S14
You can plug any ECU in to the harness and have the same thing. The starting/charging system are on a completely different circuit then the ECCS...
You can crank a car over all day with the ECU disconnected...
Madngineer
slidestyle69 wrote:thats true, good point. it seems just like when u plug a ka computer up to a sr the fp primes and turns the motor over but wont fire it off.
the qt will start the car the nq will not
Madngineer
jr_ss wrote:The NQ is most likely an SR20DE ECU, meaning it won't run your car because there are different I/O's from the SR20DET.
i just bought another NQ ecu and it runs the sr fine, i guess it was just a bad ecu
Madngineer
jr_ss wrote:You can plug any ECU in to the harness and have the same thing. The starting/charging system are on a completely different circuit then the ECCS...
ok, thanks
