S15 light problem any help w/ rela
brian963
I just installed s15 lights on my s14 and my passenger side headlight or bright light will not work. I've done just about everything from check the fuses, the bulb, change wiring, etc. I talked to a friend and he said it sounded like the relay for it was out. Does anyone know anything about the 95-96 s14 headlight relays???? The driver side light works fine, and the other two lights in the headlamp work just the projector and brights are not. If anyone has any kind of info I would appreciate it. Thanks and post or email me at [email protected]:help
Nissan-S14
Car: 95 Nissan 240SX SE
i dont think they were meant for your car, give them to me. :)
S13ChucKAT
Car: asd
WHen you installed it, did you splice into the stock harness, or use the stock harness (im not sure if they plug directly over).. but if so, and you used the stock wiring, i know the 95+ 240s' had the dual single beam headlights.. so its 4 bulbs.. IE 4 connectors.. which you should be able to just splice over.. from the HID projectors, to the brights... If i were you, id be checking ground's, and check your relays, by having someone turn on the lights, remove the drivers side headlight relay, and listen for the passenger relay.. if no noise.. the relay is dead, or try swapping the right w/ left
