s15 injectors too much for s14 turbo?
wildacexxx
Car: 2002 Q45 nav sport
are s15 injectors too much for an s14 turbo? friend is getting a good deal on a set but doesnt know if this would do much in terms of performance and instead hinder it and waste gas and plugs/o2 sensor.
DawgMode
Car: 180sx
nope....it will be fine
wildacexxx
will it increase performance? how much boost can stock s14 injectors handle out of a s14 t28?
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
250ISH WHP IS THE LIMIT ON 370CC INJECTORS.
WITH THE S15 480CC INJECTORS YOU CAN HOLD AROUND 300WHP OR ALITTLE MORE.
wildacexxx
but i doubt a s14 turbo will hit 300hp. so are they a waste?
virus77
Car: 95 S14, 71 240z, 97 e320
its a pretty good matchup actually.
DawgMode
Car: 180sx
with the right mods it could, being maxed out
Nismo_Freak
Car: 89 Nissan 240SX
You will run high into the duty cycle on the 480's but they can support 300whp.
The 370's are completely overran at 270whp.
wildacexxx
wats the most hp you can squeeze out of a s14 turbo?
spider_slayer
Car: S14 240SX
S13 240SX
depends on your other mods. i'm pretty sure its good up to 14psi.
wildacexxx
you guys also have heard about not all s14 and s15 turbos not being BB. i did some research for my friend. theres a little plate in between the housings that has a model number. well his model number doesnt match up the BB ones. so 370cc's wont stand up to well up to 14 psi?
Nismo_Freak
wildacexxx wrote:you guys also have heard about not all s14 and s15 turbos not being BB. i did some research for my friend. theres a little plate in between the housings that has a model number. well his model number doesnt match up the BB ones. so 370cc's wont stand up to well up to 14 psi?
At 14 PSI you will be pretty much maxing them out, but alot of people do it without issues.
Yeah, there are at least 4 different part numbers of the S14 and S15 turbos, and only 2 are ball bearing.
sr20detmaybe
Car: 95 240sx
what 2 are ball bearing and which 2 arent? (Edit: nevermind, found it)
PROJECTRB240SX
THERE WAS A DYNO ON FA AWHILE BACK WITH A S14 T28 THAT MADE 280WHP... I THINK THATS ABOUT CLOSE TO MAX ON THAT TURBO I BELIEVE.
wildacexxx
PROJECTRB240SX wrote:THERE WAS A DYNO ON FA AWHILE BACK WITH A S14 T28 THAT MADE 280WHP... I THINK THATS ABOUT CLOSE TO MAX ON THAT TURBO I BELIEVE.
wat injectors?
PROJECTRB240SX
I BELIEVE 550CC
