S15 HSLD install question
94_240sx
Car: 94_240SX
I'm about to start my next project s15 hlsd installation on my s13. I know I should buy new side oil seals, gasket and replace them. Are there other parts I should take care of? How about front oil seal, shims, bolts, nuts, breather, clips or washers...etc? I want to get ready before I drop the diff. Here's the R200 diagram. If you've done this before, please feel free to give me any tips or suggestions. I've read several articles, so have good idea on how to do it although I've never worked on diff before. Thanks!!!
nismofly
Car: 89 Nissan 240SX Hatch
i put new bearings and races on mine but there pretty much arent any wear items so thats all i worried about
AmoebAssassin
Car: 1991 Base fastback 5spd, black
The pinion gear is a pain to get out -- you should be fine with just replacing your oil seals on the diff. The bearings aren't really a wear bearing, like wheel bearings are.
94_240sx
Car: 94_240SX
Thanks guys. Just picked up gasket and seals today. Total was just under $50 including tax, and luckily, dealership had them in stock. I'll do this upgrade soon, take a lot of pics and do the write up for other people. I've never worked on differential before, so it will be interesting. Parts numbers are in the pics below.
Yeah, unless yours are leaking, I'd say don't sweat it.
The axle seals are easy, find a big-*** socket that matches the size of the seal, and a rubber mallet.
You can return the rear cover seal, use RTV instead.
94_240sx
Car: 94_240SX
AZhitman wrote:Yeah, unless yours are leaking, I'd say don't sweat it.The axle seals are easy, find a big-*** socket that matches the size of the seal, and a rubber mallet.You can return the rear cover seal, use RTV instead.
Okay, great tips. I have a big socket, and I'll return the cover seal since I have a tube of Nissan OEM sillicone($40+). Sillicone sealant has been working better for me anyway.
94_240sx
Car: 94_240SX
I forgot that I also picked up a breather. Price is including the breather. What was the best weight for the diff oil? I know I need to get Redline BTW.
