slepys14 »
https://forums.nicoclub.com/slepys14-u101580.html
Sun Jan 11, 2009 8:57 pm
I bought a used s15 helical diff for my s14, Installed my stock s14 ring gear with the original bolts, used the factory shims just as they were with the stock diff. Everything went well, and was tight, just as it should be. However when I drove the car there was a loud cliking. I pulled the pumpkin back out of the car. Upon closer inspection there was so much play between the pinion and the ring gear that you could turn the pinion slightly back and forth without continual gear meshing!!! I have bought different shims and tried eliminate the play without any luck!
