s15 helical lsd into a s13
yiaracer
i have a s15 helical lsd and i want to put it into my s13...what is needed to make it fit...i have an open diff...will i need to get a new housing...thanks...
red
mattlord42
Car: 1991 240SX Coupe
Okay this has been discussed on here before so someone will yell at you to search but i'm bored so I did it for you:
http://www.nissaninfiniticlub....nding
Look through those and if you have any other questions just ask.
Matt
fuzion
Car: Cars.. Web/graphic design.. Yuppp
I haven't really found a yes or no answer to this =/
yiaracer
i didn't find a straight answer....
thelinja
I installed an S15 HLSD in my S14 housing. It fits fine. The S13 diff housing is THE SAME as the S14 housing, with the exception of the cover. You will however need the HLSD output shafts. Open diff/VLSD shafts will NOT work.
When you remove the old diff, remember which side the spacers go on, you will use these same spacers, in their normal locations.
yiaracer
so it will fit into a s13 open diff then...were can i get the hlsd halfshafts...thanks
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
how much power will the hlsd's take?
thelinja
I haven't really found out anywhere you can get the halfshafts. Any USDM dealer cannot get them, nor can Courtesy Nissan. I was lucky enough to get the halfshafts with my diff. There was a good thread on http://www.zilvia.net about the output shafts, but I still haven't found a source for them unless you can somehow get ahold of a dealer in Japan.
As far as power goes, I don't know how much the HLSD can take, but I'm sure there are some pretty powerful S15's in in other countries with the stock diff still on.
