signal180sxhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=9d8f856020a0d3ad351c0f8c69882959S15 Helical LSD installed!Wed Nov 06, 2002 12:51 am
Postby
signal180sx »
https://forums.nicoclub.com/signal180sx-u1811.htmlWed Nov 06, 2002 12:51 am
After much researching and finding out how to install a s15 helical lsd properly, work was worth it down to every penny. The helical LSD performs exactly the same as my friends Nismo 2 way LSD. not as much in the decelleration portion.
I stuck the S15 LSD Hemisphere into a s13 hicas housing case with the axles and just bolted them on(after i rebuilt the axles and joints) This LSD sure performs alot better than any VLSD. I still spent 415 bucks to install this beauty. to include the LSD i got a deal on, the housing and redline gear oil.
Postby
Geoffrey_Furman »
https://forums.nicoclub.com/geoffrey-furman-u3722.htmlWed Nov 06, 2002 12:51 am
What are the details of the swap?I was told that the s15 diff uses 30tooth splines not 29t as on the s13 axle stubs. Also I was told that the ring gear bolts are 13mm not 12 or 10 and on other models.
All I have is a diff. No ring and pinion, axle stubs, are case.
Postby
bendychicken »
https://forums.nicoclub.com/bendychicken-u8295.htmlWed Nov 06, 2002 12:51 am
well, i don't know the answer to any of these questions but i'm bying a S15 HLSD this weekend. I'm going to attempt to put this thing in my 1993 s13 coupe non-abs non-lsd carrier. I'll let ya know what i run into :patriot
Postby
CaptainHenreh »
https://forums.nicoclub.com/captainhenreh-u7856.htmlWed Nov 06, 2002 12:51 am
bendychicken wrote:well, i don't know the answer to any of these questions but i'm bying a S15 HLSD this weekend. I'm going to attempt to put this thing in my 1993 s13 coupe non-abs non-lsd carrier. I'll let ya know what i run into :patriot
Please do. I'd much rather have a Helical diff than a Viscous one, but I'm not ready to shell out the grand or so that a Kaaz or Quaife will require.
Postby
chandler »
https://forums.nicoclub.com/chandler-u12379.htmlWed Nov 06, 2002 12:51 am
what stub axles did you use, and was that the same housing that came in your car? my 96 doesnt have abs, so that means it has the shorter pumpkin, ill be gettin a new driveshaft from enjuku soon, and I would love to have the hlsd also. will a s13 housing fit in an s14? it should shouldnt it?
