gpeele wrote:this is a s15 helical diff installed in a spare s13 non abs pumpkin with the correct output shafts and brand new shims, bearings and seals. all installation was done by a shop sometime ago but the shop has since closed.
just today i had the pumpkin swaped out with my stock one and it was making a loud grinding noise, like loud enough to be heard when the rear is jacked up and the wheels spin freely when the accelerator is pressed. when on the road the noise is much louder and reverbs through the car. i cant take it back to the original shop for obvious reasons, so what could be the problem, bad shims, crappy fluid (75w90 gear oil is in there now). are helical lsds themselves known to go bad? any help will be appreciated.
thanks.
well from my understanding, you're saying that you swapped the current s13 pumpkin for another one?
well if you had to remove the final drive assembly, when reconnecting the pinion side gears, you must adjust for backlash between the ring gear of the final drive as well as the main pinion drive. if its not aligned correctly or within its specs, grinding can occur.
who did the swap? if you did it by yourself, i hope you had a dial indicator on hand to measure the backlash on the ring gear and main drive pinion. and make sure to have the backlash specs. hopefully not hard to find, but in any regard, that is probably what happened during the pumpkin swapping process. adjustments are normally cured with side gear adjustments to move the ring gear and pinion in the right place.
