raw0330 »
https://forums.nicoclub.com/raw0330-u9768.html
Tue Jun 02, 2009 2:26 am
Just some info that I have never been able to find by searching, and (due to my own laziness) finally figured out.
Wiring S15 Headlights:
Highbeam is a standard 9005 connector, same as the S14
Lowbeam: The 2-pin connector for the h1 bulb is the same connector as the marker light connector on the s14 that will be remove anyways. To keep the low beams on with the highs, I soldered in a diode from the highbeam power wire.
Markers and Blinkers: This was the part I couldn't find. I REFUSE to cut, splice and hack wiring together, so I actually waited and found the same female connector. I found the connector in the main harness on a 95 Maxima right behind the left headlight/corner light. The connector didn't have a mate, and was taped in place to the main harness. Not all Maximas had this connector! I just cut off a pigtail as necessary. Total cost $4.00 and 2 days squishing around in the rain. After doing that, I found the crank sensor pigtail has the same connector on the '95 se 5-spd. the pigtail part number is 24079-70f20. Retail seems to be $40.66/ea.
