Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Sat Jun 04, 2011 4:21 am
That would be the first i've ever heard of that. Nismo has a 6 speed that utilizes a standard rear gearbox housing so s13 and s14 owners can use a regular vss. I would check inside the hole to make sure there's a gear on the tail shaft to drive the vss. After that, crack out an fsm and start chasing problems. I would start with voltage output of the vss and then continuity
