S15 gauge cluster into S13
Sintax
Not too sure if this is even a possible option, i have seen them around, and i know they have the LCD KM's and such. but has anyone gotten them to work w/ an older sr20det ECU and drive train. As i recall the S15 also had the speed sensor in a different location too...is that sensor compatable?
-scott
Daunttless
The sensor isn't compatible. : (
SpeedRacer1
Car: 1990 240SX, G35
Basically the S15 cluster is for show, or to hang on a wall. Unless you go through extensive electronic modifications which in which the ends would NOT justify the means.
Daunttless
But they're so pretty : )
Sintax
I think i may just have to get one to see how they work, maybe see if i can pull the guts out of a S13's and see if i can get them to fit into the S15 cluster, though the LCD would not work, but thats not really the main issue anyways since the KM's on the clock would not even match the motor anyways. its only $30 wasted anyways.
i'll let people know if i ever get the thing to work right.
-scott
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
i made up a new thread cause i didn't see this one. Stupid computers.. Well I love the look of the S15 gauge cluster and I'm gonna figure out how to make her work :)
My car is gonna be a hybrid.
1990 H/bRB25DET engine swapSilvia front clipS15 gauges180sx tail light conversion
"You have a what?"
It's a 15-Sil-Sky- 80!
