S15 Front End Specs
JDM240sx
Is the S15 front end "wider" than the S14 front end? I had this outrageous idea of getting an S15 front end on a S14!! :eek: I know its a bit riske... Just wondering if the S15 front will be too wide to match the lines/Shape of the S14 body. Just curious again...
SWIFT_DRIFT
well they make bolt on (plus some fabrication) s15 kits for s13's...so I would assume you could find one for an s14. But arent s14's wider than an s13? if that's the case I would be more worried that your own car is too wide for the kit :P
I don't know anything about s14's :(
Almost_S15
I've got the s15 conversion kit for the s14. the s15 hood, bumper, lights, and radiator support bolt on you just need the conversion fenders. they are fiberglass. the front end kit will run you about $2500
SpeedRacer1
Car: 1990 240SX, G35
The lines look fine to me...
BinaryVertigo
hello, i'm in california, where can one find a kit like that for an S13 or S14? thanks
Daunttless
Well, you can look up strawberry face and get all the info you need.
I'm looking sell the S13=>S15 for about 3k, and the S14=>S15 for around 2k, we'll see how the prices actually turn out though. : )
