leesredgt wrote:
Hey man i saw you the other day, do you live off of East Brainerd Rd.?
No, but I was out in that area yesterday.
StricNyne wrote:i am highly interested in doing this, i know the s14 rad support can be used, but any got pics of them using it ? my current rad support is mangled, and i can get another one for 100 bux, or pay 300 for a s15 one, what should i do ?
Using the S14 radiator support is fairly straightforward. Two holes have to be cut out to provide clearance for the S15's projector housing, and then 4 brackets need to be made from bar steel to hold the inner sides of the headlights up. At least, that's how I did it.Not sure what I would recommend in your case. The more OEM S15 parts you use in the conversion the easier it's going to be, but if you think you can modify cheaper parts to fit you can probably save a lot of money and get the same results.
