S15 calipers/rotors on S13?
redamnavit
First of all, if I missed the answer to this in my searching, I apologize. I tried all the phrases I could think of.
I have a 1993 s13 with Attain 5-lug front hubs. Can use a set of s15 calipers and rotors to this setup? My attempts at searching indicate I'll probably need new brake lines, but will everything else bolt up without issue?
Thanks.
Dystopia
Car: Nissan S13
s15 uses much of the same suspention as a r33, i belive that it would be much like doing r33 brakes on a s13
aznromeox
s15 calipers are 300zx 30mm calipers. Same thing. I had a pair also. Go for it. Just get the same things you would as a 30mm 300zx brake upgrade
Nismo_Freak
Car: 89 Nissan 240SX
S15 uses the same suspension as an S14 ... the R33 has a double wishbone front suspension, it's nothing similar to the setup we have.
You can bolt on the S15 brakes easily, it's just like doing the Z32 swap.
