I just have a simple question. What type of bulb do the S15 headlamp assemblies use? Are they H1 like the kouki's? Also, the headlamps from courtesypartsnissan say they come with connectors. Does that mean I just need to strip and solder the existing wires to those connectors to get them to work (I have a zenki)? I am thinking of doing the conversion because my front is already kind of messed up and I might as well do the s15 conversion since its about the same as getting new zenki parts.
Also would this oem s15 fender work well in the conversion or would it be easier to use an aftermarket fender like this one that is guaranteed to fit? I am planning on using this oem s15 bumper. Will I need an s15 core support or will modding the existing s14 one good enough? Also what is this and will I need it? O yea, I will probably end up using a ViS Invader hood, but not sure if imracing has one. I can't find an individual one on their site, but they have it as an option in a ViS s15 coversion kit. The following picture is from their site. How much, if any, work will be required to get that hood to fit with the previously mentioned s15 parts?
