S15 ball bearing turbo
nightstepper
Car: my girlfriend, my project car, and partying
I am almost sure that this question has been asked before, however i will ask again for my own benefit and also for others that might want to know.My question is this. How easily does the S15 turbo bolt up to the s13 redtop motor, and also does it require any significant changes or modifications? Furthermore, what kind of upgradeds (if any) would be required to do the swap effectifly? And lastly, is it efficient, and if so how?
Night-Stepper:bonghit :help
GraySilvia
Car: auto-x, drag racing, beer
It's an easy swap. You have to bend the oil and coolant lines around a little bit to make them fit. Also, your stock inlet pipe won't work unless you cut it off the flange, rotate it, and have it welded back together. If you look hard, you can find the JDM S15 intake pipe, so it'll be a bolt on. Also, the outlet pipe is at a little bit different angle, so you might have to modify your hotpipe. Mine works ok, but then again, it's a muffler shop special. Other than that, just be sure to get new gaskets while you're at it.
As far as efficiency goes, i don't know what you want to know there.
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The turbo extention also needs one of the holes redrilled if your going to use a s13/s14 extention.
GraySilvia
It didn't have to be modified on my car when i put the S14 turbo on it.....odd.
Onizuka
oh, well my greddy turbo extenion didnt line up on mine, might be different between the s13 and s14 :)
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
It's good for about 300rwhp if that's what your asking.
Tai Mai Shu
350 with cams and SSPL Rom tune
SpeedRacer1
Car: 1990 240SX, G35
Just make sure you get the early S15 model turbo. The later model S15 turbo is an S14 turbo.
Onizuka
where did you hear that? And why would they go backwards in quality?
SpeedRacer1
The early S15's got 91F00 series turbos that are equivilant to BB HKS Garret turbo's. They switched back to the S14 (75F00) turbo because the S15 turbo's were costing too much. The S14 turbo's did have a slightly lower output but the stock boost may have been increased.
You have to really look at the serial numbers on ebay turbos. I have seen real S15 turbos that have the 91F00 serial number. But I have also seen S15 turbos on ebay that have the 75F00 serial number.
http://www.nissansilvia.co.nz/...=2186
Onizuka
well my OEM replacement turbo better be ball bearing like it says
http://www.store.yahoo.com/pha....html
SpeedRacer1
My friend just ordered an S15 turbo from Wayne too, so we should know in about a week which kind it is. Wayne wasnt aware of any changes.
But heres the turbo you want...
Onizuka
i read through that thread and it seems there wasnt any diffinitive answers on weather or not the last model turbo is ball bearing or journal.
Phax
Car: Control dynamics
J-Spec Tuner wrote:i read through that thread and it seems there wasnt any diffinitive answers on weather or not the last model turbo is ball bearing or journal.
What I got out of the thread is that the latest, most recently produced "S15 turbos" are journal bearings. Only the earlier produced, "91F00 series" are ball bearing.
SpeedRacer1
S14 T28's are ball bearing.
SpeedRacer1
J-Spec Tuner wrote:well my OEM replacement turbo better be ball bearing like it says
It is the proper S15 turbo. My friend just got his.
Onizuka
SWEET :ylsuper
DriftS14
what would the gt28r say on it's serial number? Anything concrete? What does the standard t25 say on it? Standard t28? Thanks
SpeedRacer1
It depends on who you buy it from. Nissan T25's and T28's (and all the Skyline turbos) have a Nissan serial number. This will vary from the factory Garret number and from other numbers that may be selling turbos.
T25 from an S13 SR20DET = 14411 50F00T28 from an S14 SR20DET = 14411 75F00/14411 69F00/ 14411 82F01 depending on year and continent.T28 from an S15 SR20DET = 14411 91F00
DriftS14
I appreciate that. There's this guy wanting to sell me what he claims is a gt28r, and the serial number has 69F00 on it. Is it what he says it is? Thanks again
Oh, and he wants $570 shipped. What do you think?
SpeedRacer1
HAHA, not a chance its a GT2835R. The 69F00 is an S14 turbo, the S14 turbo is about 66% of a GT2835R.
S14 T28 = max of 280HPGT2835R = max of 420HP
