s15 and gt28r same?
BlkrwdT
Ive search and came up nothing . Just wondering if they are the same turbo or is there something different ? I notice on my gt28r it does not have the separator between the wastegate and the turbine. Hopefully I got the right turbo, because its the same part # as the s14 turbo(t28) 14411-69F00. How can I tell if its the real GT series?
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
The GT28R is the same as the S15 turbo. Where did you order from? You have to be carful because some places sell a journal bearing versions of the T28 turbo (as opposed to dual ball bearing).
SpeedRacer1
Car: 1990 240SX, G35
If you have a turbo that has the serial number 14411-69F00 then you got an S14 turbo. Its still a ball bearing.
Onizuka
What makes the S15 turbo differnt are materials used in the turbine and the formentioned wastegate divider.
BlkrwdT
SpeedRacer1 wrote:If you have a turbo that has the serial number 14411-69F00 then you got an S14 turbo. Its still a ball bearing.
Then what is the gt28r serial #?
SpeedRacer1
No idea but that number you gave is a Nissan part number. Nissan uses a 10 digit system.
The turbo model will be stamped on the ID tag if you got a turbo from another source other than Nissan (ie HKS, Garrett, etc).
The GT28R is good for 200-280 hp. The S14 turbo is good for basically the same amount of power. The A/R of the two are the same between the GT28R, S14 turbo and S15 turbo so they are all nearly the exact same.
