ItzGenX »
https://forums.nicoclub.com/itzgenx-u1074.html
Sun Feb 13, 2005 7:50 am
IIRC, the S15 Turbo 6 speed transmission is the same one in the 350Z, G35, and RX8 (different bell housing of course). The most popular car out of the 3 is the 350Z, so there is more of a user bank on that for error. The main problem seems to be early synchro wear for many. Same goes for the G35 (same thing anyway). The RX8 has had a few here and there popping up on boards all over the net about the 3rd gear syncro. The 4th gear syncro is showing signs of giving up in my friend's 30k mile 350Z.
On a side note, everyone thinks the S15 6 speed is weak due to fitting a 6th gear in the same space that would normally fit 5 gears. This to me is false (unless a form of proof pops up) because the 6 speed's internal gearbox is designed totally different. There is nothing in "size" that makes it the same as the 5 speed as I have seen both SR 5 and 6 speeds sitting next to each other. In fact, I think the 6 speed is stronger, just has crappy syncros.
