s14sr20 into 96 240sx final stages. i need help please. i got pics.
xdabsx
Car: 96 240sx/92 240sx coupe/94 240sx vert/95 240sx/93 240sx hatch
my car wont crank at all i turn the key and it clicks once and loses power. i got a couple of wires i dont know where they go and i dont know where the lines under the throttle body go ill put a number above the pic tell me what its supposed to do.THANKS
1 this plug comes out where the alternator plug and starter plug comes from what do i plug it into?
2 this is at the front of the lower wire harness is it a positive or a ground and where does it go?
3 these are the lines under the throttle body where do they go?i think they go to pic 4
4 i have no clue what this is i think it goes to pic 3
5 where does this line go?
help me get this running
Modified by xdabsx at 8:50 PM 4/21/2007
corey240
Car: 1993 Nissan 240SX Base Drift Machine
1 might nto be used at all, 2 is a ground. the rest, why would you try to start the motor without that stuff hooked up anyway, if its vacuum you will be lucky if it stays on for 10 seconds. hook up that ground, if it just lcicks when you try to start it. the starter is dead. go to advanced and get it tested to see if the solenoid is fried or not. the solenoid can be replaced and that usualy fixes the problem.
sbanzer123
Car: 95 s14
1. goes to your intermittand wiper box. the little brown box that goes up by the squiters
2. is the alt or starter ground. your best bet is to take the intake mani support off and try to get at it.
3. for the evap cannister. just plug it and get rid of evap
4. looks to me like a aftermarket fpr or some sort.
5 goes to the ic piping.
hope that summs it up
leroiboy
Car: 1989 Nissan 240SX Coupe
i am fighting with sr problems right now. i had that "clicking" problem-i had a ground connector missing off the starter. the starter has a male connector and has a female single prong that goes on it. that solved that problem and mine is spinning now but now i have fuel issues. hope this helps...
xdabsx
thanks guys im goin to try to get it started again tomorrow
leroiboy
well hey, let me know and maybe i can gain something from you
