Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Thu Jun 04, 2009 6:49 am
pop the oil cap, should smell like fresh oil and not burnt oil.
disconnect the cam angle sensor, this will prevent the ecu from firing the injectors or coils and will allow you to perform a comp test easily.be sure the engine is fully warmed up and the test is done with ALL spark plugs out and at wide open throttle.failing for the rb20 comp wise is 125psi, new compression is 175psi...a 3psi variance between cylinders is acceptable.
