s14ka throttle body on a s14 sr20det
godspeed
ok, we are working on a s14, and we compared the two throttle bodies and the ka one is bigger, has anyone ever put the ka on the sr20 and is it worth it?
SmithSR
Car: 240sx
measurements? bore diameter? difference in bore diameter from inlet to outlet? model year from which you got the TB? Need more info!
http://www.nissaninfiniticlub....17470
There is a lengthy reply with several links to info about TB size, and also people who have switched to KA trottle body. AND a link to the Tomei 70mm TB.
Shoot us some more info about the two throttle bodies if you could.:D
-Phil
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
I did it on my SR, you have to re-wire the TPS but if your even 1/10 competent that shouldn't be an issue. As far as HP gains I can't really tell you, I did the same thing on my CA (just bolts up onto that motor) and it seemed to help a little but I don't have any proof other than seat of the pants.
PaulOrlando, FL
MojoMan
Car: working on cars and women
I also use the ka maf. You wont notice ahuge difference but it does increase the flow.
Movingviolation240
I think you mean throttle body, not MAF.
Paul
MojoMan
oops. ya the ka tb. Ya I also dont think jwt took that into consideration on my ecu and Iv'e always had a hesitation until about 30 % throttle then it goes away mostly. A little still there.
