Seishuku wrote:I used permatex black and red on my SR, no leaks here... There's nothing wrong with those. Though gray is what Nissan uses from the factory, but silicone sealants are largely the same, usually just different temperature applications.
I would let it set for 24 hours at 50 degrees, minimum, before even thinking about putting oil back in.
The only similar thing about them is the price.
Every sillicone is VERY different. In the end of the day though, Ultra Gray (from either permetex or from 'the right stuff') works on 95% of all sillicone based seals out there...it blows Blue/ORange/Black out of the water every single time. Diffs to engines, to transmissions to anything...Ultra gray rocks. Sure Permetex now offers a 'differential sealer', but I've yet to try it as the Gray works best.
Now when it comes to super heat situations (exhaust namely), Ultra Copper is really the king. Gray works, Copper is much better. You'd laugh at some of the hack repairs on field cars and similar with Ultra copper...that stuff plain works.
