Should I need to tap one of the existing wires for +12v power supply on the F4 - M63 (Sr / ka underdash) Harnesses? specifically for the IACV-AAC and FICD
After I finished wiring it up, I went thru every sensor under the hood (associated with sr) and ran the testwith voltmeter using the FSM to tested them for power / function. Besides lengthening of the few wires, is this all that is needed to run the motor fine? I havent started the AC wiring nor have I attached power steering yet. First wiring project, and just wanted to hear what others thought, and if Im coming close to completion.
EDIT: going without AC for now
