blacksrjdm »
https://forums.nicoclub.com/blacksrjdm-u52167.html
Tue Dec 29, 2009 10:01 am
Keep searching and you will find quite a few threads about this topic. Been covered many many many many times and since you already knew that "this question has probably been asked hundreds of times but here we go again", Why make another thread about it.
PS. I also had the same exact luck as numbnuts, Its like the second link in google if you type in "s14 kouki conversion". U may have searched but not this topic, or you would have found proper info.
BTW, your topic is misleading also, because your topic is stating that s14 Zenki is better than (>) Kouki. And by your statments and what you want to do, it would seem that you like the Kouki > Zenki.
Also seems that the level of fail in this thread is awfully high. Seen higher, but this is pretty close.
